Basement Bathroom Plumb & Shower
3.9K views 44 replies 10 participants last post by  C'est Moi
Hello all and happy Saturday.
I'm going to DIY the plumbing for my basement bathroom.
I have a question about where I want to locate the shower.
I'm not sure about a shower pan and how much floor space I need for it. No tub.
Someone mentioned a corner show but not sure I want that.
right now w/o the sheetrock I have 60"x26 1/2". I assume molding by the door molding will take up some room.
For reference looking at my drawing and the 60" wall by the shower you'll see in the picture there is no wood base plate on the floor yet.
BTW I bought this guys Ebook/diagrams. He seems pretty good.
Thank you very much.
How will you work out an access to the clean outs in a shower? What a labyrinth of plumbing pipes? How are you going to get the drain water to the level of the exit, pump?
#7 ·
TheEplumber has a point and it seems the OP it turning his back on a big issue. 26 1/2” is not wide enough for a shower, code or no code. 30” is cramped, so a usable show should be 32” wide, especially if it is going to be 60” long. Maybe on that back wall would be a better location.
#8 ·
If you want a bathroom in your basement, it appears you will need to install a sewer ejector pump and pit. It appears your sewer system exists your home, at least 3 foot from the floor of your basement. You will need something to pump the sewer water from the bathroom high enough to exit in the main sewer pipe. You surly know this right, before all of that carpentry work.
#9 ·
I had to make wife's new shower 32" because I couldn't find a 34" preformed pan. We normally built 36" deep pans from scratch and I like that better. Her shower does seem to be narrow to me. I couldn't imagine a 26" shower.
#16 ·
You'll see picture 1534 where there is no bottom plate. I can bump out that wall to the left several inches ...it just encroaches on the stairs a little bit as you can see in pic 1532., the opening when come down the stairs into the basement will be a little smaller.
#32 ·
As you can see, like idiots, we framed before plumbing roughing. So now when i have to break up the concrete to get the piping to rise up between the frame and foundation(in other words, behind the wall) I guess(obviously) I need to remove the bottom stud???
#36 ·
You are asking for a whole peck of trouble burying that house trap in the wall like that. That cast iron is old and that house trap will cause issues at some point down the road. That access will not be enough if major work needs to be done. Why not change it all out. Are house traps still part of code in your area. They are no longer code in my area and taken out.
#45 ·
If you are getting old it is good to have some blocking near the toilet so you can mount a grab bar to help get up and down. I put one in at our house for when my mom would come over. Now I can use it if I need it.
Towel rods are notorious for pulling out of the wall because they were mounted without any wood backing in the wall..
