Installing this heater in my garage. Not a plumber/gas fitter.
I don't have access to the attic space, so I need to do everything either from under the ceiling or above the roof.
Can cut a square out of the drywall and screw the fire stop / support plate to the ceiling ? Or must it actually go inside the attic? I was hoping I can sandwich some strapping on the attic side of the drywall to give some backing to screw the plate to.
In regards to the insulation spacer, I figured I'd just put some 6 or 8" around the Bvent inside the attic from the top to keep insulation away from the b vent. I figure I can slide this in from the roof side.
Does this sound acceptable / code compliant ?
