Hey Everyone,
I installed an Aprilaire 700 a week ago and have had limited success with getting the humidity up in my house. Here are the details:
And now the concerns:
Thanks!
- Installed on the return plenum due to very limited space on the supply side (see pictures)
- Using the included Model 60 humidistat mounted about 7" above the unit to control it
- Tried settings 4-6 on the humidistat dial
- Piped into the hot water line
- Not using the outdoor temperature sensor
- We live in Colorado at about 6,500 feet
- House is 5300 sq. ft including the basement. Above ground is about 3,400 sq. ft.
- Humidifier doesn't always turn on when the furnace does
- Tankless water heater feeds the unit, but I'm not sure I'm truly getting hot water to the unit because I don't think the draw is enough to turn on the heater
- Originally had it set for automatic blower activation so that it didn't have to wait for the furnace to turn on, but the fans were running almost all day. I know that setting is typically only if you're using hot water with the unit, which I'm not sure that I am
Thanks!
