This will get kinda wordy, but I wanna try to explain everything, to get a "best bang for the buck" plan.
I have a description and photo, so keep scrolling
I moved in this house at the very end of July, so as winter went along, and spring approaches, I'm finding new water issues that need resolved.
I need to address my lawn irrigation, or lack there of. In this first picture, is the layout of what I am planning. The yellow highlight, is going to be the route I take to run a french drain to get any and all rain water away from the house. Currently, the grass slopes towards the red drain that I show in the photo. There is currently no drain at that location. My thought is to run the french drain from the back corner of the garage, along the garage and driveway, then have it meet the drain where it will then go to the left in front of the patio. As it continues in front of the patio, it will then turn left and head out towards the front of the house, out towards the main road. The run from the back corner of the garage, towards the house, and then passing in front of the patio is a good 100ft. That is my plan for the routing. (Right where the proposed drain will go, is a spot that I believe is the big reason I have water flowing into the basement at that exact corner of the house. So anything to help any excess water to be moved away from that spot, the better)
In this photo, you will see the run along the garage / driveway that I need to address. If you look at this photo, you will see what looks to be a temporary ditch dug, and it has a slope which moves water away from the garage. It is working wonderfully. I did that a few months ago to keep the garage from flooding, and that trench is doing it's job. Now I'd like to get a drain pipe in the ground, to be able to close that temporary trench up, and make it all grass like it used to be. I plan is to extend that trench on down the line where it will meet the drain I mentioned above.
This picture is what I cam across yesterday when my basement went into flood beast mode. I had water coming in everywhere. Not knowing what I had, there was about a 12" wide strip of gravel that passed in front of the patio, which was also barricaded by landscaping timbers that divided the rock / grass. I expected to dig into the gravel and see nothing but a half assed excuse for a drain. I certainly didn't have to dig far to see a green irrigation pipe. I did come across a landscaping fabric that was layed on top of the pipe, and that was under the top layer of gravel. I lifted the pipe up and noticed the drain holes ran parallel to the ground, on the sides. The pipe is caked with mud, and very little water , if any, was able to enter into the pipe to drain. The end of the pipe where you see the white cap, is the end cap. This was all under water once I was able to get to it. You will see 3 holes on top of that cap. I drilled those hoping for a relief hole that would allow that water to go out. Once I drilled, that water went down like the water in a toilet, really quick
I thought about pulling the pipe up and cleaning it out, and re-using. But we're only talking 25ft. So I would rather pull it up, and lay down new. Lay a new drain in, and where the white cap is, that is where I would have that drain in the first photo.
So now I have the trench that would be from the garage, to the front of that patio, running parallel to the patio, meeting the gutter downspout, and now it will turn left and go out towards the road. This is the photo you see here. This isn't as important as the above info. Whatever drain type I decide to go with, will also be used for this run. You will see the corner of the patio, where the downspout is, where I will continue the drain.
If you made it this far, thank you
Here are my questions. I have watched a number of videos on what to use, and what options there are. Anywhere from schedule 40, corrugated black pipe, perforated green pipe, and that popcorn drain (EZ drain, I think it's called). Then I need to also include the water / dirt barrier fabric, as well as all the gravel.
1. Schedule 40 - for the total length of pipe I would need, this is currently $20 per 10ft. I would need to manually drill the holes in the side for draining. None of the areas that I am placing this drain will ever see vehicle or heavy weight on top of it. So I think sched 40 is over kill.
2. The green pipe is currently being used, that's not a deal breaker. Certainly cheaper than the sched 40. I'd still need the fabric and gravel.
3. I did see another thin walled white drain pipe at Home Depot today, that had the holes in it also. I wasn't sure what the difference between the green pipe and this. I tend to think it was the thickness. But both were in the same price range.
4. The black corrugated pipe is stupid cheap. Obviously the best bet when it comes to budget. But I hear / read it's junk. 100ft for $40 sure is appealing. BUt again, need the fabric and gravel.
5. EZ drain / popcorn pipe - That is friggin easy as it gets. but that $40 per 10ft is a killer. That does save me from buying gravel. I have not priced gravel to compare the overall price. I know I will need a lot.
I am going to re-use the gravel that I pulled out from in front of the patio. But the 75ft run from the garage has no gravel.
This is where I need advice. I don't know which option would be best for what I am doing. Does it simply come down to budget, and all will do the job just fine?
Am I overthinking the drain? I realize it is temporary and that it won't last forever. But I certainly don't want to dig up every year to have to redo. End goal is to certainly get rid of all the standing water, and any water that leads into the basement. Any suggestions / advice would be appreciated. If I forgot to mention anything, please ask.
I will be digging the trench from the garage to the "new drain location" here in the next day or so, just ot keep that water moving. With us having no rain for awhile, that would allow me to get that water to flow down into this trench pipe (green) that I drilled holes into. that green pipe does flow out on the side of the house, at least it does now that I drilled new holes. The pipe is definitely clear from the downspout onward. Just the pipe in front of the patio is not playing nice. time to update
