Do you always use a metal bead for inside corners? I have been doing a few just by filling it with mud. Or will it crack?
the way I have seen it done is with a straight knife into the corner from each side. No corner knife. You don't need one because the bead is the corner.OK, I guess that makes some senseI would normally recommend using an inside corner knife regardless. Even though many pros discount them, they work very well, especially if you don't do taping for a living. Personally I don't think the corner bead above would save much time because you still have to embed the tape the same way and you still have to use the corner knife the same way. Really the drywall itself should be straight, and the above isn't much different from just a piece of paper tape. But whatever floats your boat!
