Adding supplies and return to a newly-sealed crawlspace
3.1K views 19 replies 7 participants last post by  wrbrb
4 options under 18 code which as I recall is the same for the 21:
Continuously running exhaust at 5 CFM
The HVAC option as noted above but the walls must be insulated & sealed AND it is based off volume. It says the entire area, not just the floor area as the prior one does. Plus you must remember the area encompasses everything up to the floor sheathing above - so you are probably closer to a minimum of 25 CFM based on the pics.
3 is not an option - treat whole thing as mechanical plenum
The 4th which is a new addition is a dehumidifier sized at 70 pints (as I recall not an option in earlier versions)
