My home has a 200A service and in the past when I had to wire up a GFCI receptacle for one of my sump pumps in my basement, I did so by adding a 20A breaker into the panel after running a short strand of AWG 12 w/ ground for the wiring. I went with the 20A breaker based on the guidence I received by one of my local electricians that I hired before for a separate job. He said to use the 20A breaker because anything larger like a 30A or up wouldn't get tripped if anything bad happened, so I did and haven't had any issues with it since I installed it. It works like a charm, verified using one of those GFCI plug probes that has different lights to confirm proper functionality.
Well, I want to do this again for another sump pump that I have in my basement of the same type because the receptacle for that one lacks a ground (the contractors who installed it back when I was a tenant retrofit the power cord to bypass the lack of ground as the receptacle isn't even a GFCI (it's an old house and was like this before I moved in). I want to fix this.
So if I add another 20A breaker to the panel and wire everything up the same way I did last time, will that be okay? I figure I'd just snap another 20A breaker right below the one I installed last time and run the line exactly like I did with the other. I think the only question is distance because this newer line will have a length that would be close to 15 feet... Will that be an issue for the wire type?
The sump pumps I use in my basement are the Zoeller M67 Solid Waste model--these guys are awesome. I use them both for managing rainwater drainage, not sewage. From what I understand, they each use 115V at 10.4A and 60Hz.
Thanks in advance.
Thanks in advance.
