What wiring and wire nuts do I need to make a pigtail for connecting an existing outlet to a new outlet? Adding an outdoor outlet on the same stud cavity and just behind the existing indoor outlet. Need about 12 inches or wiring to connect to the outlet. Will drill hole through exterior stucco, exterior mount a weatherproof 1 gang box, 15 amp damp rated GFCI, and in-use cover it's the TayMac kit MKG420CS kit.
Connecting new outlet to 15 amp outlet in a bedroom and I can see if it's using 12 or 14 gauge wiring when I open it up. Everything here is solid strand so I'll need either 12 or 14 gauge solid strand wire. What's the best wire to use? I can get stranded Black/White/Green CU THHN Tri-Wire or Southwire Stranded White Copper THHN Wire by the foot or by the role and wire nuts at the local stores.
I always make sure power is off when working and verify with a non-contact voltage detector and multi-meter and have the various hand tools the side cutter, wire strippers, screwdrivers, hammer drill and bits, stud finder, etcetera.
Thanks.
Thanks.
