6X14 Beam Span
7.2K views 8 replies 7 participants last post by  Nealtw
I am in the process of remodeling a house I just purchased and there is a 6x6 post holding up a 6x14 beam right in front of the front door and I am hoping to be able to remove the post so it is not right in your face as you enter the house.
House built in 1979 in southern California. The post was hidden by a 12' wide rock wall. I removed the rock wall and discovered the 6x6post. I am assuming that it is structural, but only because built into the rock wall was a wood fireplace (being removed) and on the roof above the fireplace is 12' wide stucco chimney cap so I am assuming that the post was installed to help support the additional weight of the chimney cap. I am having the house re-roofed (was original roof and it is clearly time to re-roof) and will be removing the chimney cap so I am hopeful the post can also be removed. Been scouring the internet for span tables and can't find any that reference a 6x14 center beam.
The room with the beam has a vaulted ceiling and is in the center of the house with living space on either side so there is no overhang from the rafters. The rafters span is 13'. Beam is 6x14 x 35 feet. There are support posts at either end of the room and there is a 28' span between them. The post I want to remove is 8' away from one end of the room (so 20' away from the other end of the room). The beam overhangs the end supports by 3' on one end and 4' on the other. The pitch of the roof is 4:12. The rafters are 2x8s 16" on center and attach to the ridge board above the 6x14 beam. The roofing material is standard weight concrete tile (so 970 pounds per 100 sqft). The beam is wood but I am not sure of the species but am assuming Douglas Fir.
I hope that is enough info for someone to give me an idea if they think this is is even possible. I do intend on hiring a structural engineer but wanted to ask this forum first before I spend money on a structural engineer. If the consensus here is that its not possible I will not be hiring and will figure something else out or maybe leave (ugh!) the post where it is. The last thing I want to do is remove the post and have the roof collapse.
651597
651598
28 ft is really long for a 14" beam and the structure over the door does not seem big enough for the total load. You may have 2 beams meeting over the FP.
You will want that engineer to sign off before removing support. I would expect bad news.
My guess is no you can 't remove it since I don't see any real support at the end. I do not see a post at the end visible in the picuture. There is some sort of post coming down over the door. But is does not go all the way to floor to offer support. The header above the door does not look large enough to transfer the load.
You need an on site inspection by a structural engineer.
#5 ·
Your 2 x 8 rafters have a ridge board and all that is sitting on your 14 inch tall beam I can see it from the front of the house doesn’t look like you’re going to be able to take out the post or the beam.
#6 ·
Seeing the post upon entering the front door will be WAY less of an obstruction than seeing the massive fireplace wall. Learn to live with it. Columns can be a feature. See this pic for an idea how to dress up a 6x6 column.
#8 ·
I want to stay thanks to all who responded and gave me some great advice. In the end, I did hire a structural engineer and while I was disappointed that I could not just take the post out, he did have an alternate solution that achieved essentially the same thing I was trying to do. His design incorporated a 6x16x26 ft polylaminate beam that rests on 2 4x6 posts in the walls. Beam actually rests above the top plate in the wall for even more weight distribution across the walls. Once the drywall and painting is all finished I think it will look amazing. Thanks again for all your input.
654419
And now when you walk in my front door instead of seeing a 6x6 post, this is the view.
654423
I am stoked!!
