6/3 wire to sub panel 60 amp
Tags
#6/3
16K views 23 replies 7 participants last post by  Winchester875
The breaker size is to protect the wire, NO use a 50 amp breaker
A bigger problem is you do not have enough wires for the sub panel.
You need 4 wires, hot, hot, neutral and ground
The cable you stated will not be correct for current codes.
What I know about plasma you need a lot bigger panel and circuit as the the plasma and compressor run full tilt until you stop cutting.
