3/8" PEX (1/2" OD) to Dishwasher?
25K views 28 replies 13 participants last post by  BayouRunner
#1 · (Edited)
Unfortunately the forum won't allow me to search for "PEX" because it's too short, so I couldn't find any information on this.
I've got 3/8" PEX (1/2" O.D.) coming from my wall and I'm trying to install my new Whirlpool dishwasher. The dishwasher takes the typical garden hose fitting. I spent 45 minutes at Home Depot trying to come up with a way to make this connection to end up with a way that takes 3 separate fittings. I personally would like to stick with one fitting, but so far I've come up empty handed.
This Sharkbite U2276LFA fitting would be perfect, but it's too small. I even called Shark Bite to confirm that they don't make the fitting that I need. (They don't)
Does anyone have any clues?
Attached is a picture of what my line looked like. There was a nut somehow attached to the line...I cut that off because I bought that Sharkbite fitting and thought that it was correct only to find that it wouldn't work, so now it's just a PEX line without any hardware on it.
I had an existing dishwasher, but it was 13 years old and broke. This is a dedicated PEX line to the dishwasher. The entire house is plumbed with PEX with individual valves to each service.
The faucet has its own PEX hot and cold lines. No tees.
#4 ·
Ayuh,..... That Was a 3/8" compression fittin', with a crush sleeve,....
Probably still the Best way to get where ya wanta be,....
You'd go with a 3/8" compression to 1/2" male pipe fittin',....
To a Hose adapter that's threaded 1/2" pipe,..... many are threaded 1/2" Id/ 3/4" Od,...
You can probably find both fittin's in a boxstore,...
I know ya can in a quality hardware store,....
#5 · (Edited)
no way to go from your sized PEX to 3/4 hose thread without transitions...
they make a 3/8 push fit that transitions to 3/8 MNPT.
A DW hookup kit with braided hose will connect to the 3/8 MNPT
& also come with an angled adapter for 3/4 hose X 3/8 MNPT adapter...
Peace
#7 · (Edited)
I had a similar scenario trying to simplify a connection to laundry tub faucets. Initially I wanted to run PEX right to the faucet adapters and eliminate the need for intermediate flexible hose step. However, I read somewhere the importance of the hosing - vibrations from the appliance will not affect the rigid plumbing if you have a hose between the appliance and the rigid plumbing. Furthermore, if you want to pull the appliance out a few inches to inspect behind it, or if you accidentally kick it or nudge it somehow, you're not going to damage the rigid plumbing. It's less of an issue with PEX, but definitely an issue with copper. So it's worth reconsidering the hose option (plus there's way more options for 3/8" hose to faucet connections - it's harder to find 3/8" PEX fittings).
#11 ·
PEX sucks ass. I can NOT connect my new dishwasher after the last one broke and I refuse to pay for a plumber. Does anyone on here actually have advice on how to connect PEX plumbing to a dishwasher without having to spend hundreds of dollars on the tools or a plumber? I miss my old house right now.
#15 ·
Sorry, I miss spoke. It is pex. It does have a valve, but that valve isn't threaded. So looks like I have to do pex again. I'm not willing to drop hundreds of dollars on tools for 1 project and hiring someone to install a dishwasher which should be simple is out of the question.
#27 ·
I have a pex pipe exactly as the picture from the original poster, with a nut somehow attached. This nut was attached to an elbow connector directly to the old dishwasher. Problem is that I didn't save that elbow. I have no idea what the sizing was on it. I would like to use the the flexible braided hose and elbow that came with the kit and somehow attach it to the pex water supply line with the crazy nut thing on it. Any ideas? Also, for the sharkbite solution do I cut the end of the pex with the nut off?
