2" Foam Board for Interior Wall Insulation
4.9K views 24 replies 12 participants last post by  Bud9051
I'm wondering if I can use 2" foam board for interior wall insulation instead of fiberglass batts. The reason is that my home is basically a 100 year old shell of solid wood. In the 80s, it was renovated and 2x4 were put inside, with a gap in between the studs and the exterior. Rats are a huge issue out here and with this gap, it creates a highway for them to reach all parts of the home from behind the wall. All of the fiberglass insulation was nested in. I'm hoping that I can solve this problem with spray foam to fill the gap between the studs and exterior wall and 2" foam board instead of fiberglass, cut to fit between studs. Might add another 1" foam board across the studs, and place drywall over it. Is this solution plausible? Any other ideas?
Thanks in advance.
Worked on a house with lots of blue foam board and the rats loved it. Made for a nice warm winter home. On another house the home owner had flattened a soup can and nailed it over a rat hole. Not a problem, they chewed right through those 2 layers of metal.
As suggested, locate where they are getting in but also be aggressive at trapping.
Bud
Reactions: SPS-1
Bud
When I first got the house, I was killing them in the hundreds. Previous tenants were hoarders. Situation is much more manageable now, but there is an endless hoarde out here. I'm hoping that foam board continues to be effective insulation where fiber glass has fallen down and become useless.
Im sure the foam won't stop the rats, but I'm hoping that it will be less attractive as bedding and maintain effectiveness where the fiber glass has just fallen down in 90% of the home. I still plan on solving the rat issue from the crawl space and attic, but 100% rat free is near impossible here.
Foam board is a good insulation remembering its negative side of needing a thermal barrier. But it is also great for air sealing which can be a real problem with the older homes. Be sure all wall cavities interior and exterior walls are fire blocked.
Good luck
Bud
Good luck
Bud
Thanks for this info. I hadn't really considered any additional requirements for foam board.
I sealed the gaps behind each stud with spray foam (great stuf fire block), does this count as fireblocking?
For the thermal barrier, would 5/8" drywall be considered enough?
#16 ·
After you close the rat highway, consider spray foam insulation instead of the rigid board.
It will seal tightly, save you money by lowering your energy costs and be more efficient.
#18 ·
Certainly take care of rat problem first. Have several rental properties that I bought as tragedies and had rats. Find the opening. If you have a shared wall, you are already screwed. In one property we ran a soaker hose under the bat insulation and pumped and ammonia mixture through it into the cavity soaking everything daily for a month. The floor, walls and insulation keeps the smell for a while and did a good job at preventing the rats. Dropped the treatment to 1 time per month.
Cap opening with steel mesh. They can chew through tin cans...not steel mesh.
#19 ·
I think you're on the right track. Open cell spray urethane on the walls is nice if you can afford it. Or keep on truckin. Install the ridgid insulation between the studs as good as you can and seal with spray foam.
My concern is moisture. This type of wall will need to dry to the outside. Hopefully no moisture barrier. I'd Install visqueen vapor barrier over the insulation. Although the foam will not transfer moisture easily. Your call again, your looking at it. Another layer of insulation over the top of everything will act as a thermal barrier. Not sure about how thick of insulation you can go under the drywall and not worry about sag. Ask a drywall hanger.
I believe a firewall has seams taped and mudded. 1/2" on walls 16oc, 5/8" if 24"oc. 5/8" on the ceiling.
Man I can only wish you best of luck with your rat issue. Have you considered metal roofing inside ? I would need to put an electric fence where they hang out.
#25 ·
Rigid foam, spray or sheet, has a balance issue where the ratio of rigid (cold side) vs the fluffy insulation (warm side) needs to maintain the dew point within the foam insulation. If it ends up inside the fluffy insulation it can result in condensation where you don't want it. So, too little foam or too much fluffy can be a problem. The charts that illustrate the advised balance have disappeared, mostly now behind paywalls. If needed I may have a copy saved somewhere.
Bud
