How to plumb rear outlet toilet?
51K views 25 replies 4 participants last post by  Alan
Hello, I am trying to figure out how to plumb the toilet I am going to be installing in the basement. It will be flushing into a 4 inch cleanout cap but I also am adding a sink drain to it and need a vent for the toilet while adding another cleanout. I am thinking about using one of these 3x3x3x2 double Y hubs (picture attached) to connect to the stack (via cleanout adapter and 4-3" reducer), the toilet, and new cleanout cap for the 3 inch ends while the 2 inch is the drain for the sink. Can I just vent the toilet in a T off that 2 inch side between the sink drain and the hub?
#7 ·
I haven't built the walls or run any pipe yet. I want to have the plumbing figured out before I start. I plan on putting them next to each other with both attached to the same wall. (Facing the toilet) the sink will be on the left draining to the right into the 2 inch part of the hub with the 3 inch center one having the new cleanout.
#20 ·
So what you need is a 4x2 combo fitting with a 2x2x1-1/2" sanitary tee on top of it facing horizontally in the wall, and then use a 1-1/2" long sweep 90 to stub the drain out of the wall where your lavatory will be.
The top of your sanitary tee becomes the vent for both fixtures and needs to be tied into another vent in the house.
#22 ·
Yep, and i think the orientation of the two upper fittings are obvious (I think that's why you labelled them as 90 degree turns) but if I haven't mentioned it yet, you want the drain outlet to be around 19" high from the floor unless you have some kind of funky furniture cabinet that requires the drain to be in a specific place.
#23 ·
The drain line for the sink at 19" or higher above the floor? Doing that won't be an issue I think. Why is 19 the magic number if I may ask? The cabinet I bought is a basic one from one of the box stores. Cabinet with sink on sale for $39 was hard to pass up.
Also, should I use a separate vent line from the sink and meet up with the one for the toilet or does this vent allow for both. It'll be less than 5' of pipe from the sink to the tee.
