Underground Wiring
1.7K views 9 replies 6 participants last post by  curiousB
I've finally settled on using pvc for a 30' run from my house to a shed. It will be 18" deep, be 3/4", and have 3 conductors + ground, all THWN solid (I have not liked working with stranded, can't seem to wire nut it properly).
1. Will I need to have the warning tape over the pipe location?
2. I plan on coming up through the floor of the shed straight into a load center panel. Is this okay or do I need to come up outside, have a Type LB conduit body and go through the wall?
3. If coming straight up into the panel is that good enough for wire pulling, or will I need to put some kind of device in the vertical run like a Type T conduit body?
4. Rather than pulling individual wires, would 12/3 UF work as long as my fill is less than 40%? Might be easier, as I would have it in there as I assemble.
Twist strands before you terminate
No, but it is a good idea-I do it.
Conduit body not needed. Schedule 80 for this part of run if exposed and subject to damage.
UF is fine, for 1 cable fill is 53%.
What size circuit are you running? #12/3 sounds like a 20A MWBC, yet you mention panel?
Anytime you dig a trench, make sure you put something in the trench you will be glad you put in the trench years from now. UF cable is not something I would use and I highly discourage this. Lay PVC conduit in the trench double the size you actually need. That's just me and how I would do it.
I would come up through the floor like you plan and do. Straight up into the panel.
#4 ·
Maybe I wasn't clear, but I would put the UF 12/3 in sch 80 pvc, I just think it will be easier to put in. I guess you are saying it is 53% fill in a 3/4" conduit? I'll verify. Will probably go with the 1" anyway. I am running 12/3 to a load center, I want a set of breakers in the shed. I have a second 20A 2P GFCI breaker at the main source panel. The outlets are also fed from a 20A GFCI in the shed, hopefully that or the breaker in the load center would trip first in event of a mishap, save me a trip back into the house. The load center and 20A 2P breaker were only $30.
#5 ·
12/3+g in a 3/4" is fine.
Double GFCI protection not necessary.
53% is what you base you conduit fill on, not 40% for one cable. Chapter 9, Table 1, note 9.
(9) A multiconductor cable or flexible cord of two or more
conductors shall be treated as a single conductor for
calculating percentage conduit fill area. For cables that
have elliptical cross sections, the cross-sectional area
calculation shall be based on using the major diameter
of the ellipse as a circle diameter
#7 ·
I got a used 20A 2P GFCI breaker for my panel for $40. If it becomes a problem, the non-GFCI ones are relatively inexpensive. I understand the GFCI units may not coordinate, the one in the main panel may trip first, I guess I could run a test.:)
Is it okay to also run coax along with the power in the underground conduit? Does the code care? I may want cable TV in my shed!
#8 ·
You will need to install a separate conduit for the cable tv it's not a good idea to have it with the power wires and code does not allow it.
Also you will want coax rated for direct burial so it will last.
#10 ·
Inductive coupling of power into coax. Will create other problems. Also code forbids mixing such services in a common conduit. If you use underground grade coax it doesn't need conduit. Put in power conduit and backfill a few inches they lay in coax and complete backfill. Maybe warning tape over coax noting cables below...
