Removing old blown-in insulation in attic?
5.6K views 11 replies 7 participants last post by  Justgaff
I've seen/read about a machine that basically vacuums out the old blown in insulation. So I assume its some type of very big vacuum. I have a couple of questions:
1) Can re-use the insulation, correct? Is it not recommended?
2) Where do I find someone that does this? Would most any insulation install company do this?
3) What is the machine called and can I rent it somewhere?
#4 ·
Yeah, good question. If it's in the way, move it, if it's not enough, add to it. Unless it is damaged by mold or infestation leave it be.
1) NOT recommended, nor possible I believe.
2)Google. Most should be able to remove and replace with new.
3) Don't know the the name,don't think you can for removal. You can rent to install thou.
