Outlet placement suggestions
3.1K views 13 replies 6 participants last post by  Leah Frances
HI;
On the dining side of the kitchen, I will have a counter that runs right below the window. There is not enough room on either side of the window for an outlet, because one side is next to a wall and the other side in next to the fridge. The room between the counter any the window is very minimal and is not enough for a outlet.
I will put a outlet in the wall, but it will be a 7' long counter before it meets up with the fridge.
Do you think I should consider some type of in cabinet outlet?
Thanks
Jamie
HI;
Thanks
Jamie
Can you cut a receptacle into the front of the cabinet?
#4 ·
Yes, I was kind of thinking that might be what I need to do. We are building all oak cabinets for the kitchen, so I can design them to have an outlet anywhere. If I go that route, I was just trying to picture in my mind how to make the outlet look decent on the oak cabinets.
Since this is the dining area, just the 6' rule would apply to this counter top, correct? So perhaps just adding one outlet towards the middle would work well?
Thank You,
Jamie
I am all in favor of doing work to code. Let's hear it for those guys at the NEC [clap clap clap].
That being said. I will end up mounting a rec in the floor, underneath a radiator, where no one will ever conceivably use it (or see it for that matter), but it will meet code.
What about above the windows?
#6 · (Edited)
This is a kitchen counter correct? You need your required receptacles...
Plug Mold here we come!!!! :) Jamie, you better review sections 210.52 (C) 1-5
Exception to (5): To comply with the conditions specified in (1) or (2), receptacle outlets
shall be permitted to be mounted not more than 300 mm (12 in.) below the countertop.
Receptacles mounted below a countertop in accordance with this exception shall not be​
located where the countertop extends more than 150 mm (6 in.) beyond its support base.
#9 ·
What is Plug Mold? This is the dining side of the kitchen, I am not clear on where the distinction is made between counter that require receptacles at 24" and areas that don't.
This part of the kitchen has always had a table in it, and was for dining, not food prep. I am adding the cabinets / counter so I have the cabinet space, and the counter top is really to put plants on, but I want it to be up to code.
Jamie
#12 ·
Can you build some sort of box/panel/cube thing that would sit on top of the counter that would butt up against the bottom of the window? Like a "step" up to the window. If it ran the length of the counter you could put 2 or 3 outlets on this box and run all the wires behind it. You could stain it to match the cabinet color or your window trim color.
#13 ·
HI
Actually I like that idea. I would have to have the counter at a lower height though to all for room, the counter at 36" is just tight to the window sill. But if I ran it at 32" I could put a box like that there. Or might be even able to get some into the wall if I did drop it 4".
I'll have to consider that option as well.
Thanks
Jamie
