New construction window
1.5K views 13 replies 8 participants last post by  Windows on Wash
When you have rigid foam on your house can you still use new construction windows or do they need to be replacement windows? Reason I ask is because lets say you add an inch or two of rigid foam then your increasing your wall thickness and not sure how installing a new construction window would work since you using the nailing flanges and using the outer framing to fasten it.
#9 ·
So many choices, why is there rigid foam?
Here we use 2" foam and stucco all the time. And then the choice is, are we replacing all the windows, are we trying to match a existing window detail.
There really is not a right or wrong way.
What existing exterior siding and window trim detail do you have that you want to match?
Oh yeah, pics do help.
#11 ·
When you have exterior rigid foam in addition to the sheathing should you apply the house wrap before the rigid foam directly to the sheathing or over the rigid foam? My thinking is the house wrap needs to be the last line of defense against any possible water getting in so I would fasten directly to sheathing. But if you do that you should integrate the house wrap with the flashing, therefore, the window would have to go in before the rigid foam, correct?
#13 ·
no.. the window goes in after the foam is installed. it goes right on top
depending on the type of foam used and the method its manufactured you may not need house wrap. type 2 foam that has a shiplap on it does not require house wrap in some regions.. as the ship lap acts like a flashing so any water that runs down the wall wont leak in and get at the sheathing
#14 ·
Kirk,
I agree to the extent that the outie install makes for the cleanest look and most seamless installation but there are situations (and they can easily be flashed an accommodated) where you can set the window tight to the sheathing and create the box detail on the exterior.
Not my favorite but I have seen it done properly in retrofit applications as well as new construction.
