I've never had a problem with double wax rings leaking. If you decide to use two, make sure they're nice and warm, which shouldn't be a problem this time of year. If they're not pliable enough you can fill the lav sink with an inch of hot water or so and let them sit for a couple minutes. I like the rings with the polyethylene flange, but you'll need to pull the flange out of the top ring or buy one without out the flange. Once you stack them on top of each other mold them with your fingers to seal the two together.
