Hello all! I need help on how to remove an old standup shower
20K views 21 replies 6 participants last post by  6ft3soldier
so I can replace it, ive looked around and I cant find a how to on this. I have the showerhead off and the hot and cold knobs off but im having a problem removing bottom that connect the drain. thanks
What is the drain set up like---what is the pan made of?
If the pan is plastic or fiberglass--I will usually take a Skillsaw and make several plunge cuts around the drain--this way you can remove the old pan--leaving only the pipe-the drain set-and a bit of the pan around the drain set.
If you will be replacing the P-trap(which you really aught to do)--You should see enough of the drain piping to get a saws all blade down the hole and cut out the old P-trap.
If you hope to save the old drain piping(bad plan)--You can chuck a hack saw blade into the Saws All and slit the old drain set up the side and pry it off the old piping.
Post a picture,if you can--or at least come back and tell us what the base is made of.
Lots of people here that have done what you are trying to do.--Have fun--Mike--
#4 ·
Im not even sure what its made of ill take a photo of it , is it difficult to post photos here?
#7 ·
#6 ·
Common materials that shower bases were(and are) made of--
1965 and newer--fiber glass--pvc and other plastics
1950 --1970--terrazzo--concrete with a steel pan--colored pebbles embedded in the surface --then ground and polished
1920---1960's--lead pan--concrete and tile
1990--present--rubber or vinyl liner--concrete--tile
2000--present---Styrofoam pan--water proof membrane ---tile
These are just the roughest outlines of types and dates---Terrazzo bases are still available--
some tradesmen use 'old fashioned' methods that work for them--but this should give you a clue as to what you may be looking at.
---Mike----
#11 · (Edited)
Good start Soldier--We need an over all shot so we can figure out what it's made of.
Can you see if the drain pipe is white PVC or metal?
==Mike---
Ill take another shot of the whole shower and ill look down in there to see if I can see the drain pipe
Pipe is white so im assuming PVC pipe
#13 ·
You're probably going to have to remove the entire unit(walls first) to get the base out. The walls will sit inside the base to make sure the water is contained.
Do you intend to enlarge the shower?
Ron
#20 ·
Most shower drains are not designed to be removed---On The older ones the pan is sealed to the pipe with okum and molten lead--
The newer ones use a rubber dough nut-- hammered in between the pan and the pipe.
If you wanted to save the pan I suppose a person could work for a few hours and pick the seal out--
But to scrap the old thing it's easier to quickly destroy the pan --then SawsAll the remaining parts off the pipe.
I could have had that thing in the dumpster in less time than all of this typing has taken!!!!
---Mike----
#21 ·
Sometimes those drain nuts rust on so you can't get them off. I wonder if that's what he is trying to do. I wish I'd known years ago that I could just cut one fo those down the middle with a metal sawzall blade. We made do without a shower for a long time before I decided to just demo the whole thing and replace it.
