dropped my pc
5.8K views 4 replies 4 participants last post by  joewho
Hi everyone HELP. i dropped my pc and now it starts up for about 3 seconds then cuts out. the processor cooling fan starts going then all goes off. and you have to wait a few seconds before trying it again. i havnt got a clue and dont want to buy another pc if i dont need to.
Thanks mat125
so the computer starts up but then locks up or bluescreens later?
that could be a heating issue.
you may have knocked your heatsink off your processor or it is loose. make sure the heatsink and the fan on top are not loose whatsoever and are making direct contact to the cpu. you can also buy something called "thermalpaste" and put it in between your cpu and heatsink if you find that was the cause of the problem. the thermal paste will help the heat flow off of the cpu and into the heatsink making your computer run more smoothly :)
still nothing
thanks for the advice, that still doesnt seem to work my pc seems to want to start and sometimes goes a little while longer but doesnt regester on my monitor. i hope this makes sense. when i used to turn on my pc it would place the win xp load screen on the monitor, now however i get nothing because the tower doesnt stay on long enough.
mat125
