Hi.. I have a York PC9 (Modulating Upflow with ECM Motor).. at least that is what my service manual says.. After reading a number of posts, I was able to determine the error code (7 red flashes). I believe the furnace is locked out because of no ignition... the manual suggests checking the gas supply, ignitor, gasvalve and flame sensor.
Is this something I can do? Is it just a regulating type thing, I noticed there is a regulating knob... or is this just a cleaning problem that perhaps I might be able to do? If I turn on the blower from the thermostat, then try again, it sometimes works.. I have also turned off the power for a few seconds, then back on.. the light begins to flash a slow green, and the furnace once again seems to be working.
If I had to call a technician, would you recommend one that works specifically on a York Furnace, even though many advertise they work on all brands.
Thanks,
Ken
Thanks,
Ken
