I have a furnace(p3urc20n09501e) that is suffering from lack of ignition. I have traced the problem to a likely faulty pressure switch by:
-. Inducer motor runs, blower runs, but pilot/heating element never triggers, followed by 3 blinking LED that manual describes as unable to close pressure switch.
-. Putting hand against inlet air duct outside can sometimes trigger ignition. (no longer seems to work)
-. Slight movements on pressure switch wiring can sometimes trigger ignition.
This switch, 024-27634-000, has two barbed connections. One to the burn box and one to the inducer motor. I believe tripping based on pressure differential.
I looked for a replacement switch, but a vendor recommended one is a single port switch.
My question is in multiple parts:
1. Does swapping switch make sense? Any other causes I should be looking into?
2. How to install the new switch? Install the single-ported one and crimp the unconnected hose to the burn box?
Thanks for any advice
