Just purchased a house with a new York AE series hvac unit installed. The heater is electric and model 6HK16501006C heating coil. When the blower increases speed the heating coil makes a high pitched squeaking noise. I can only assume it's from one or several of the ceramic insulators on the heating coil. As seen in the photo some of the outer insulators have more wiggle room then inner ones which may be the issue. Has anyone experienced this issue with an electric heater and found a good solution?
I have some super lube grease which I could put on the metal rail the ceramic insulators sit on, but, this would be a very tedious fix. Before anyone posts about the blower motor bearings or the grease, I have already confirmed it is NOT the bearings and super lube is a dielectric and rated for 230°C so there should be no issue if it's used.
