Is 3/4 inch yellow polly gas pipe the correct size for a sixty ft run between LP tank and house?
R Randall Woods · Registered Joined Dec 7, 2012 · 1 Posts Discussion Starter · #1 · Dec 7, 2012 Only show this user Is 3/4 inch yellow polly gas pipe the correct size for a sixty ft run between LP tank and house?
TheEplumber · Premium Member Joined Jul 20, 2010 · 12,447 Posts #2 · Dec 7, 2012 Only show this user Randall Woods said: Is 3/4 inch yellow polly gas pipe the correct size for a sixty ft run between LP tank and house? Click to expand... Not enough info. Google LP gas sizing
H hvac benny · Registered Joined Dec 29, 2009 · 738 Posts #3 · Dec 7, 2012 Only show this user You also need to factor in pressure and total load. I'm assuming you mean 60' from tank to second stage regulator at the house?
