So, I know there are countless threads in this forum and others about basement insulation. I have spent many hours reading them as well as articles from BuildingScience.com. With that being said, I'm not 100% sure if I should go with 1" or 2" XPS foam boards.
Background:
I have a Cape Cod style home built in 1951. I live in southern New York, climate zone 5. The foundation is made from concrete block. The house had water infiltration problems when I first moved in 8 years ago. Since then, I have installed an interior perimeter drainage system below the slab and a sump pump.
I currently have a moisture issue in one corner of the basement after several days of heavy rain. I plan on digging down and sealing the exterior foundation wall with tar extending out about 5-6 feet from the corner. I will also regrade and extend the downspout 10 feet from the house.
Question:
What combination of insulation should I use for my basement?
I started out by insulating my rim joists with 2” XPS as described in this article from Family Handyman. Based on the reading that I’ve done, I want to go with XPS rigid foam boards glued directly to the foundation. My building inspector said that I need to have at least R13 insulation in the walls, so the 2” XPS alone (R10) is not enough.
This second article from Family Handyman says to use ¾” XPS on the walls, frame, and later fill with fiberglass.
Then I came across two articles from Building Science Corporation. The first BSC article says using 2” XPS along with R13 fiberglass works very well at controlling moisture when used with spray foam on the rim joists and another 2” of XPS below the slab. But I don’t have anything below the slab.
If I’m reading the second BSC article correctly, it says that using 1” XPS with R13 fiberglass can also be effective at controlling moisture as long as the sheet rock is covered with vapor barrier paint and a dehumidifier is located in the basement. But… the article states that “some variations not recommended” and the article does not explain what that means.
So, will 1” XPS with fiberglass be thick enough for moisture control or will I need to go with the 2” XPS and fiberglass?
Background:
Question:
