I am trying to find a toilet that will fit into my new half bath, and the roughin is to center 10 3/4" from the finished wall in concrete... so it can't be moved any...
would this toilet fit?
http://pdf.lowes.com/dimensionsguides/650531971128_meas.pdf
or should I just find a 10" rough in toilet and be done with it even though they are more expensive?
that toilet has 10 1/4" to the center and back it seems like it would fit with little back clearance, but not 100% sure
Premium Member
You could try it-
I read 2 different dimensions on the spec sheet- 10 1/4" & 11"
Discussion Starter #4
maybe i missed something...it a 12" rough in...you need a 10":eek::eek: ben sr
Kohler has this wierd habbit of having tons of extra space behind the toilet... we put one in upstairs that was 11" rough in, the toilet had a 12" roughin requirement and there was still over 2" between the wall and the tank back :no:
Reactions: ben's plumbing
that is the floor foot print tank hangs back the other 3/4 inch on cut sheet but i to think kohler gives a lot of wall space. ounce i thought it was a 10 rough bowl in a 12 inch opening at a house
