I am adding a socket to an external wall that already has solid foam insulation and plasterboard on it.
I have cut a hole for a gang with a pad saw. Turns out the insulation and plaster board total 25mm deep.
Unfortunately most drywall gangs are deeper than 25mm. But i have a metal gang that is 25mm deep that slides in and i can screw it to the solid wall behind.
Is there any reason not to install a metal gang in plasterboard? Am i setting up a condensation trap? Should i insert plastic patress instead?
