1 - 8 of 8 Posts
I just power washed my pressure treated deck yesterday, and I need to decide what finish to use.
If I use a semi-transparent stain, will it be much more work than a wood toner, the next time I have to re-do it?
Does a semi-transparent stain last much longer than a wood toner?
Is there a certain brand product you would recommend for either?
Thanks.
· Premium Member
Ask any painter how much he likes doing decks, ugh! Not much of anything lasts for more than a couple years. Even the high priced stuff fails quickly. My "go-to" product is CWF-UV made by the Flood Co. It's cheap, easy to recoat after a couple seasons in the weather, and gives that nice warm look to PT wood.
Here's the link to a great source of info about decks:
www.deckstainhelp.com
· Premium Member
Thanks. I saw the CWF-UV today at Menards. It's not a stain, correct? It's just a wood toner? When it gets re-done in 2-3 years, does it have to be cleaned and power washed again?
Well, Jim, you really should clean it again before re-coating. It's amazing how much dust, dirt, pollen, etc. finds its way onto the deck surface and you don't want to apply a clear coat over any of that. On the positive side, if you do it up right this time around, well, it will go much better and much faster. CWF-UV is readily available and I would venture to say Menard's has the best price on it. Probably less than $20 per gallon.
1 - 8 of 8 Posts
