1 - 20 of 23 Posts
I have and old vented propane heater in my gargage Its way to expensive to run so i bought a woodstove. The stove has an 8 inch pipe. the garage is block with siding on the outside. what do i need to do to get that pipe threw the wall without melting my siding or catching the garage on fire. Ive been looking online for information it im not having any luck. Also the cheaper the better.
Can you go through the roof instead?
It's not going to be cheap by any means to run it right.
If you go out the wall your going to need a wall stand to suppport the vertical piping, lined pipe so it's cool enough to not melt the siding, standoffs to support the pipe, it has to be run above the roof line and also need a cap.
http://www.selkirkcorp.com/installation-guides/Default.aspx?id=292
Reactions: kevin07
No idea on exact cost. Look though the site I posted to get an idea on what needs to be done to keep it safe. No need to buy that exact brand, just wanted you to know that parts are needed
Still would need a thimple where it goes through the ceiling that holds the pipe and keeps it from moving and a roof jack rain shield and cap.
Discussion Starter · #6 ·
ok i was thinking of using single wall pipe because its cheaper i have a drywall celing what would i need to do around this to stay safe but not have a big hole arond the stove pipe for clearance. Sorry for the dumb questions i have no experience with wood stoves.
Single wall would burn out within a year or so.
No double wall can not come in contact with the siding.
No it can not even come in contact with the drywall. It was to be at least 2" form any combustable material.
Reactions: oh'mike
I am usually an advocate of doing things yourself but, in some instances it is time to call in someone who knows what they are doing. You (the OP) indicated that you have no experience with wood stoves. My brother recently had one installed in his home. Single story thru the roof. I was impressed with the care and knowledge that the installer had when opening up the roof and installing the proper roof safe and piping. Properly sized pipe is important based on the stove to ensure proper heat retention in the pipe so it does not get too cool or too hot. Both of these situations can cause problems for the stove, chimney, structure. I would advise to at least seek out some expert opinions on a proper instalation.
· In Loving Memory
vynl siding. Would double wall be cool enough to have the siding tuching it? or would i need a thimble? Also would 2 90s and all single wall cause a draft issue?
Would still need a thimble. The pipe would need to be a flue pipe rated for solid fuel. And it would still have a min clearance needed from the siding. Single wall clearances are much greater then All fuel requirements.
EG: On gas, B vent requires 1" all the way around it, single wall pipe requires 6" all the way around it.
· Retired Moderator
Going out the wall will cost more than roof----
Danpik made a good point---flue sizing is key to proper drafting of the smoke----
Most stoves use 6" --so do find out what is the correct pipe size for your project---
Discussion Starter · #15 ·
It is a used stove its a Schrader it has an 8" single wall pipe attached to it. I will be doing the install not paying anyone to do it. I just need to do my research and find the proper way to install it and i will follow the all the requirement to make it safe. I think im just going to find a local store that sells woodstoves and pipe and talk to them to see what my options are.
The advantage to running it through the roof is that you can use single-wall pipe up to the roof line, or ceiling in your case. So you need a thimble deal to go through the ceiling, then a brace deal at the roof and a roof flashing deal, then a storm collar and a cap. The triple wall stuff is pricey.
Another advantage is that you will get more heat off the single wall pipe.
If it is 8 inch you should be able to find someone that has some 8 inch triple wall they bought by mistake and are willing to sell. You are asking for big big trouble not at least seeking expert advice. For one you will never get an 8 inch outlet stove to work properly unless you know what you are dealing with. The day that thing back drafts and blows the door open with hot embers remember my warning. You need to get the idea of single wall being very dangerous. I would say minimum 1000 dollars for an install to code, not sure on the labor, good luck. Oh, your insurance company is not going to cover the damages this stove is most likely to do.
Discussion Starter · #18 ·
Did a bunch of research and orderd all the parts i need total was $530 Im running single wall to the celing then changing over to chimney pipe at the pipe support in the celing then sleave deal for inulation, flashing for going through the roof storm collor and cap.
paintdrying, the wood stove isnt goin to cause any damages ... mabe try to sound like a little less of a smart ass
1 - 20 of 23 Posts
