Almost done with converting an enclosed porch into living space. I found the perfect match wood flooring that is in my living room. The new room floor is 3/4" OSB with a nice vapor barrier and locking laminate tile that is floating. The tile pieces are mostly 1' by 3'. Locked together. If the tile is in place, the wood floor matches perfectly in height when I sit planks on it. So, can I nail the hardwood directly over the laminate tiles? If I can, does there need to be some type of barrier between the tile and and wood planks. Can I just take the vapor barrier under the tile out and lay it on top of the tile? So it would then be 3/4" OSB, laminate tile, vapor barrier, then wood floor planks. Can a floor/blind nailer penetrate through laminate tile. They are pretty tough.
