Couple of questions:
1). When wiring receptacles with (two sets of white and brass terminals - one top and one bottom) does it matter if the IN FEED wire (Neutral/hot) and OUT FEED wire (neutral/hot) goes on the top or bottom terminal pairs? or is the voltage going to pass through to the next outlet either way?
2). Looking at the various wiring diagrams on Google I see people wire these in different ways, some use the receptacles as a passthrough for the voltage and some use a wire nut and use only one set of terminals on the receptacle instead of two. Outside of not relying on each outlet to pass-through the voltage does this 2nd method have any other benefits over the first option?
Thanks
Thanks
