Greetings,
I'm looking to build a workshop on the back corner of my lot. I have the building quoted, concrete quoted, permit info, etc. What I don't have is the electrical run sorted out. I've researched and listed the amp draws of all of my tools below:
Item Amp Draw
Dust Collector 9
Table Saw 5
Router Table 15
Planer 15
Jointer 12
Belt Sander 5
Bandsaw 10
Air Compressor 15
Drill Press 8
Circular Saw 15
Mitre Saw 15
Hand Jig Saw 6
Scroll Saw 2
Orbital Sander 3
Palm Sander 2
Hand Router 12
Obviously I still need to account for florescent lighting and HVAC. I will have a window A/C unit and a TBD heat source. Looking over that list it looks like my peak amp draw would be (lighting + a/c unit + dust collector + table saw + ac compressor), which totals (10 + 10 + 9 + 15 + 15 = 59). This makes me believe an 80 amp sub-panel will work.
The total length of the run to the shop will be 250 feet, rounding up. First question is, what gauge of wire do I need to run underground to the workshop? After doing some reading online it looks like 8 gauge will work but it is pretty expensive.
Also, I'm unsure of my house's current capabilities. My basement has two breaker panels, a larger and obviously older one, and a smaller one. The bottom of the post has photos of each. If it can be determined from looking at these panels, do I have the capacity to run an 80 amp subpanel off of the house? Obviously I could call an electrician but I'm over budget as is and would like to get an idea of exactly what I need done before calling/paying anyone.
Thanks for any advice provided.
Main panel:
Sub Panel:
Item Amp Draw
Dust Collector 9
Table Saw 5
Router Table 15
Planer 15
Jointer 12
Belt Sander 5
Bandsaw 10
Air Compressor 15
Drill Press 8
Circular Saw 15
Mitre Saw 15
Hand Jig Saw 6
Scroll Saw 2
Orbital Sander 3
Palm Sander 2
Hand Router 12
Main panel:
Sub Panel:
