I've been struggling trying to figure out the wiring of a new thermostat. Oil, forced hot air and AC.
The existing system has 6 wires. It is running off of a EWC-ST-2E control system. - Pic of manual attached. Wiring of existing system in the attached files.
I tried to install a new Honeywell Wifi unit (RTH6580WF). Talked to Honeywell and they said I only needed the W, R, G, and Y wire. Said to take the existing B or O wire and connect it to a common (C) for power. This configuration worked for Zone 1.
The issue I have is that with this configuration, Zone 2 (which is only 3 wires) stopped working.
I can't seem to figure out how Zone 1 is impacting Zone 2.
Any thoughts? Can I even use the new thermostat with this control unit?
Thanks,
Mike
Thanks,
Mike
