A question from a novice trying to learn more about electrical. As a beginning project, I want to improve my attic lighting by installing a run of lights along ridge beam. I have my power source coming up somewhere in the middle of the run, and id like to put my switch further down (by attic hatch) but also in the middle of the run of lights. My question is there an easy way to wire this going through the boxes i will be installing for the lights and then have a leg for the switch? I know that i can reroute the power source to the switch and then continue on to the light run, which is what i will probably do, but was curious if there was another way with wiring because the conduit already goes up to the ridge beam for the existing light and it just got me thinking. And would like to minimize running conduit.
(Yes, im in chicagloland and conduit is code from what i know.). Picture should help explain it better.
