I spent $200 on this motor and capacitor and I'm hoping for some assurance from one of you pros out there before I wire it incorrectly and kill it.
Photo 1: The motor and capacitor. Photo 2/3: Plate info on motor. Photo 4: Info from capacitor. Is this correct---> I think I should connect the black wire from the 110VAC power source to the black and blue wires on the motor, connect the white wire from the power source to the yellow wire from the motor, and the white wire also to one side of the capacitor, connect the other side of the capacitor to the red wire from the motor. As for grounding everything, if I connect the ground from the power source to the metal frame of the piece I'm building, would I also need a ground coming off the motor? Maybe under one of the motor mounting screws?
All advice appreciated. Thanks for your time.
unklerichie
unklerichie
