Rather new to this forum, as well as household electrical. I am in the process of remodeling my garage. I have completed the majority of work, excluding electrical. I have a 2 year old home, and when the house was built, they only installed 1 (one) receptacle (GFCI) in the garage. As I am sure most of you know, you cannot have just one recept in the garage. What I am planning on doing is tapping off of that GFCI recept and into a hard wired power strip (made for racetrack wiring), and then from power strip, up the wall (using the racetrack) and into a switch, then up to the hard wired shop light underneth my cabnets. In hopes, this is what I would like to happen. I am not too concerned about the look of the raised racetrack, because I am planning on covering that wall with a peg board anyways, hiding the raceway.
My questions start with the GFCI. When I pulled the recept out of the wall, I found what looked to me like this was in the middle of a run. Like I stated previously, that is the only thing is on that circuit. In the box, there is 2 romex wires coming into the box. So I have 2 sets of black/white/ground, the grounds are twisted together and ran to the recept. The whites both have a small pigtail (I beleive that the romex was initially cut to short, and this is used to lengthen it to the recept), and the blacks are the same way as the whites. Now on the rear of the recept, there are 4 holes out of 8 being used. Does this sound correct? And can I still tap off of this recptacle? Any help would be great. I hope I made myself clear, and I think I might go take a picture of it to post in here for you. Thanks
Albatraz
Albatraz
