I removed a switch and an plug outlet from two seperate lines. I thought I put the switch and the outlet back on the same line but when i went to turn the switch on it buzzed and then popped the breaker. Ended up frying that one as it would turn back on so i replaced the breaker. The switch goes to garbage disposal, when i test continuity on each wire they all show as 0-.1 range, when i test voltage i get 120 at both lines at the box. Nothing else changed so i must have hooked them up back wards, but im confused by the reading. Shouldnt the switch just be a hot loop so if you tested both wires it wouldnt be 120 until you hit a neutral, or is it completing the circuit through the disposal?
Im going to hope for a quick response before i try anything else, id like to understand whats going on and what the reading should be. Thanks!
