Looking to install Inline duct fan (boosters) to some of my HVAC duct work to improve circulation to master bedroom. We have a two story house, The plenum is in the attic, the Master is downstairs and furthest run from unit and gets the least amount of flow despite two 10" ducts and a 12" x 12" return. I have tried restricting flow to other rooms with little improvement.
I want to try installing two 10" inline 120 VAC duct booster fans. I am looking at some that have a power cord. There are some temp switches available to provide on/off control but they seem "cheesy". I would rather the fans to just turn on when the AC's fan is turned on.
Can I wire an outlet that is powered by the same output to the AC fan? This seems to be the easiest idea, just plug in the booster fans to an outlet that is powered when the main unit comes on and turns off when cycled down.
Is there any risk to the central air unit, in the event that on of the duct fans fails or goes to ground? If so, Would a GFCI proved enough protection?
Should I consider a relay of some sort to isolate the fans from the main unit?
This is a Lennox unit about 10 yrs old. I have had to have the control circuit board replaced following a lightning strike.
Open to any suggestions.
Houston, TX area.
Houston, TX area.
