1 - 2 of 2 Posts
I recently re wired my basement with multiple switches on one circuit. In order for everything beyond the switch to not be controlled by the switch i put in a junction box and ran from there to the switches. I have two questions... Is there anything wrong with what I've done and 2 what is the correct way to wire a circuit with a switch in the middle of it and not having it control everything beyond that switch. I'm a carpenter trying to play sparky and unfortunately shop class was a few years ago.
Super Moderator
If power comes into the switch then simply connect you circuit past the switch to the power in cable and not to the switch.
If this is a switch loop setup then you need to run a three wire cable instead of two wire cable so that you can bring the neutral into the switch box.
There is no problem using a junction box as long it remains accessible. You can't bury under drywall.
1 - 2 of 2 Posts
