We had an attempted home burglary/invasion while we was home early one morning. Now I want motion lights around my house.
I want two motion lights in the front yard and two motion lights in the back yard. All motion lights will use 2 95watt bulbs. I want one switch to control the front yard and one switch to control the back yard. I want them on switches so I can override the motion if needed.
I will be using 12 gauge wire on a 20 amp breaker. I was told the wiring and breaker might be overkill, but I want to be able to turn on all lights at the same time.
My question is on the wiring. I know I must run the main wire to the switches, then from one switch(front) to one front yard light then from that light to the other front yard light. Do the same for the other switch on the back yard lights.
Now how do you hook up 2 switches off one main wire?
What I'm wanting in diagram
Also tell me what kind of switches I will need.
