I am about to start making a permanent hookup for a portable generator. The plan is to install a manual transfer switch and to put a remote inlet on the wall of my attached garage.
So for the wiring, my plan is to run 10-3 romex from the panel, across the basement and go through the rim joist and into the garage. From there I was thinking of running conduit straight up the wall and into a surface mounted 30 amp inlet box. The walls in the garage are dry wall.
My questions are these:
1. Is it OK to run romex in conduit like this?
2. Would it be better to just fish the wire behind the drywall and come out straight into the back of the inlet box?
3. How high off the floor should the inlet box be, and are there any other requirements for placement?
4. Anything else I should think of?
Thanks!
Thanks!
