Hi
I have a construction heater rated at 4800W. it will be installed on a 30 amp double pole breaker. I had this installed in my previous house. and over there, it seems it had been installed using 12/2 wire (red, black and ground).
it worked for years but now I doubting if it wasn't done wrong
from what I understand the 30 amp breaker can take up to 7200W (30* 240) so plenty of room for the heater
Now, if using 12/2 wire then that means it can't take more than 20amps correct? and given the same math that would give me exactly 4800W (20 *240)
they had the red and black on either side and the ground on the bottom screw of the plug. but looking online today I saw that they used a 10/3 and brought red and black to either side and the neutral to third screw (bottom) where I had the ground before. I presume the ground wire would just be screwed to the box in this scenario?
see image in link
http://www.do-it-yourself-help.com/images/30amp_receptacle.gif
I had ripped out the heater, plug and wires when I left as my ex didn't need or want it.
can it go back with 12/2 or is it necessary to upgrade to 10/3?
if I don't have to install 10/3 that would save me some money as I have the old wiring...
thanks
see image in link
thanks
