I have furnace that is currently controlled by a simple electronic thermostat on the fritz, and an evaporative cooler. I'd like to combine the control into a modern wifi thermostat, but I am lost with the wiring:
The furnace is a simple 2-wire control. connect the wires and the furnace runs, disconnect and it stops. The thermostat I am using now is battery powered, so it simply opens and closes a relay.
The evaporative cooler is controlled by a "White Rodgers 8A18Z-2" Unit, which uses 4 wires (can't post a link here, but a description is available online. Google "White Rodgers 8A18Z-2" ) that connect to W, R, Y, and G terminals on the mercury switch. This switch also controls fan speed, and to switch between "cool" and "vent".
I have bought a Honeywell RT9580 WiFI Thermostat, but I can't figure out how to connect the wires.
2 complications: I can't find a c-wire anywhere, which I apparently need to run the thermostat, and
To avoid the cooler and the furnace battling to death, they are on a manual switch that only powers either the cooler OR the furnace. I suppose I would have to bypass that switch, as the thermostat would prevent both from running at the same time.
Hopefully someone here can shed some light on this for me. Thanks.
