Ok here it goes. I am new to anything electrical. I bought my first home in January. My kitchen had an outdated dome type ceiling with 6 fluorescent lights under it and a ceiling fan/light in the center. I removed it all. The lights and fan had worked from the same switch. The light on the fan never worked even after replacing the bulb. I bought a second hand vintage chandelier type light with 4 small bulbs that I want to hang in the center of the kitchen where the fan had been.
When I took down the old lights I did not keep track of what wires connected to what, I thought I would remember and of course I didn't. Oops :/ Anyway, when I went to hang the new light I saw that there are 6 wires coming from the ceiling. The colors are white, brown, green, red, yellow and blue. The 2 wires on the light fixture are the same color. Nothing to set them apart. The 6 colored wires go from the center of the ceiling,across the ceiling and into a hole at the top of the wall above the light switch. After trying every possible color combination with the 6 wires and the light to no avail, I then removed the light switch plate and saw that the switch has 2 black wires and one white wire attached to 2 screws on the right side. The 2 black on the top and the white to the bottom screw. The one pair of black and white wires come from the top of the little metal box. The other black wire comes from or maybe goes out a hole in the right side of the metal box to I don't know where. I have now bought 2 cheap voltage testers. One is a non contact and it reacts to every wire that I point it at. The other tester is the type with 2 wires coming off with points and it does not react to any of the wires in the light switch. I am stumped at what to do next. I do not want to rip out a section of my wall to find where the six wires go. Please help!
