Long time lurker and raised in the rural south, grew up always doing my own work. Plumbing, electrical, roofing, woodworking, mechanical, etc... "anything worth doing right is worth doing it yourself"
2 story home is in Atlanta, GA (Cobb).
Attic accessible by a fold down ladder. Outlet box is within 6' of the access hole, my running board is just past 6' but less than 7'. Attic cannot be used for storage as there is several inches of blown insulation over the joists. The HVAC (evap, air handler, natural gas furnace) is on plywood but not enough room to store anything. "Walking" is by means of placing my feet in the V of the webs.
This switch (last pic - backstabswitch) is the type of work that occurred with the former owner. Not sure who the work was done by, but seems to be a lot of backstabbing in the deal! And of course, romex was strung from web to web so as to make a nice place to hang things (sarcasm)
I want to get all this to NEC code.
Main question - exposed outlet boxes. I am using the hard plastic Carlons attached to the web of the roof. I haven't found by google, search on diychatroom, nor Wiring Simplified if I MUST use metal boxes. Will the plastic boxes pass an inspection?
My supply (14-2 NM) comes up from below, runs along a web, then along the 1x4 running board I just installed to a 2 gang outlet box (35cu/in) with switch (controls furnace only) and receptacle
4 neutrals wirenutted:
supply
furnace
wire out to 2nd outlet box
pigtail to receptacle
4 hots wirenutted:
supply
pigtail to furnace switch
5 grounds wirenutted:
supply
furnace
light
(to do list: get a switch with a ground screw - this would be the 6th)
I piggybacked the light's neutral and hot to the 2nd set of screws on the receptacle since it would have the least power draw. The light is a 60w equivalent CFL. I replaced the exposed bulb fixture with one with a bulb cover to avoid dealing with mercury from accidentally breaking the exposed bulb. New light fixture is pull chain, like the old, but with a bulb cover.
Wires appear loose because I haven't nailed the insulated staples all the way in (yet).
I installed a new 2 gang outlet box (35cu/in) for OTA antenna amplifier, and for power supply bricks for networking equipment. I have a 1x12 mounting board to nail up and span 2 webs which I'll install the equipment.
No wire is within 6" or so from the roof deck.
Wire to furnace is almost straight down. Code violation? I can run it down the web and along a joist and come up thru the plywood the HVAC rests on.
Also that thermostaticly controlled roof fan does not work. It's MC wire from the fan to the thermostat box. It had 12-2 NM dangling from the box to the old gangbox. I plan to mount a running board from web to web and use NM wire to the box (using a NM clamp connector to the box's KO)
IF I get the fan working - I'll add a junction box at the web closest to the fan as that 2 gang box is getting crowded. Good plan?
What all can you see wrong with the electrical? Thanks! And yes I'll be back so your replies will be appreciated....
And of course this thread is useless without pics!
supply
furnace
4 hots wirenutted:
supply
supply
furnace
light
