I am having some issues wiring my Central Air unit.
Currently there is a red two wire 12G wire running from the AC unit to a 20A Non Fusible, Pull Out Disconnect Switch. Then a Orange Two Wire 10G from the Disconnect to the Breaker Panel. The disconnect has four term screws labeled Load/Line on each. The Wire from the machine has Red to Line and Black to Load on one side, the wire to the panel has a White wire to Line and Black to Load.
Once at the breaker, I have wired the white wire to common/trip and the black to the other side of a 2 Pole 20 Amp Circuit Breaker.
I keep tripping the breaker .... What am i doing wrong.
Is it at the disconnect?
