1 - 1 of 1 Posts
hi can anybody give me some tips i have a light in my shed and put in a double plug socket (RING FINAL CIRCUIT) i need to run a wire from the plug socket in the shed and somehow join the wiring to the existing security wiring light can it be done with a joint box my plan is see below
from the double socket in shed feed pvc cable with a earth, live and negative wire through hole then run along out of shed and secure with plastic clips then under a slab with plastic tubbing up the wall of the house then spilt security lighting wire and join with a joint box do i use 2 way or 3 way and conect all wires to joint box plus do i need to put a higher rate fuse in the cosummer unit box for the downstairs plug sockets? or would my idea be dangeress?
1 - 1 of 1 Posts
