Hello to all.
My companion built a lightbox 14" L x 10" W x 5" H out of wood. A lightbox is similar to the boxes used by doctors to view x-Rays. Mine will be used to view photographic negatives.
Inside will be two keyless sockets mounted horizontally on metal brackets and two spiral compact fluorescent bulbs that will draw 26 watts each, as per the label on the package. Holes on the bottom of the box will provide ventilation.
I intend to use an extension cord, after I cut off the connector and leave alone the plug that came with it, to connect the box to an electric outlet only while in use.
I don't know how to wire the box in a way that both light bulb sockets will be connected to the one cord that will be plugged into the wall outlet while making sure that both bulbs will glow at full intensity and not at 50% capacity each. I imagine that a couple of sections of cord will have to be used between the sockets but I don't know what gauge is the right one and how to inter connect the sockets.
Your comments and help with my little project will be appreciated.
