1 - 19 of 19 Posts
Hi all,
Today my air conditioner stopped running in the middle of the day - we have an HVAC unit outside, central air, and an electric furnace. All controlled by the thermostat on the wall. Thermostat was blank, nothing on the screen, and unresponsive. I opened it up, but no batteries, just wiring leading to the furnace in the garage. Shut off the power, and opened up the furnace to find a bit of scorching/burnt spot on the insulation inside, and some burned/melted wires. Pictures attached show the burnt wires and information about the unit. It's a Carrier brand Electric Furnace.
You can see a couple of wires joined together with a blue cap that look nice and tidy, and then you can see the melted disaster next to it with a burned cap that's fallen to the bottom of the unit.
Now, I don't know anything about furnaces and very little about working with electrical wiring.
My first thought though is that I should be able to cut these wires back, screw a new cap on them, and fire up the furnace. If I do that, are they going to just melt down again? Is there a way to get at the root of this problem and fix it so it doesn't happen again?
Thanks everyone for any help you can provide!
Update! I picked up a new cap, cut back the melted wires and then stripped about 3/4" off the ends, screwed on a new cap, and then flipped the power back on to the furnace. Thing fired right up, thermostat display back on, cold air blowing, all's working normally. Feels pretty good to DIY! Thanks for the help joed!
hi, just an observation.
The large black wires, are they copper or aluminum? If aluminum you may have the wrong kind of wirenuts, which may explain the overheating of the connection. looks like there is an aluminum ground/neutral wire in the background. You may want to post this on the electrical forum.
bernie
the special nut has some type of anti-corrosion compound in it right? stops the aluminum and copper from reacting or something.
There will be no neutral, it's a 208/230V furnace. I don't care for wire nuts in high amp draw situations, I much prefer split bolt connectors, wrapped in mastic, and sealed with tape. Very rare to overheat a connection then.
Wood Building Bicycle wheel Gas Electrical wiring
Electrical wiring Gas Cable Electrical supply Electronic device
Electricity Electrical wiring Cable Gas Electrical supply
Electricity Electrical wiring Cable Gas Electronic engineering
Bicycle tire Automotive tire Automotive lighting Bicycle handlebar Motor vehicle
Electrical wiring Electricity Cable Gas Wire
I know this is an old thread but I had recently googled my problem and this site’s thread and image showed up. I can’t find any similar images that match what my problem is. This thread is close and related to my problem. I do believe after reading these comments that whoever installed this did not use the proper purple connectors for aluminum and copper. My problem is I know that these wires need to be cleaned up a bit and given the proper connectors just like how the original guy did with his post here. My blue wires look pretty bad and one of my blue wires don’t seem to connect to anything. I need to know where these wires need to go and to which place. I wished this post showed the full component because it’s just such a close match to my unit.
You'll need to replace some of that wiring. You'll need 14awg for any of the control wiring and appropriate connectors. You'll need a wire stripper and crimper. You'll need whatever the larger wire is. All of it needs to be rated for the same temp as the original.
@beenthere or other mods please make this a separate thread.
1 - 19 of 19 Posts
