hi all,
this project ties to my Spa project (see http://www.diychatroom.com/f49/spa-208358/)
but this one deserves its own thread. gonna be building a rolling credenza for my backyard and will have TV, stereo, cd/dvd, wifi, all 100% wireless. yep, designed to run at 200watt for 6hrs on lithium batteries !! sounds crazy, but thats the type of projects i do. the TV will also be on a lift, so it hides inside the credenza when not in use. i recently got a 43" visio from B&H on sale, so got a good deal on that item. TV lifts are way to much $$$ to buy, so i am making my own. to buy a lift is around $500, but as of now my working pneumatic has only cost me $35! granted, i need some peripheral items to make the lift function, but probably less than another $100 for that. i could not find any cots pneumatics of the size and price i need, so i made my own pneumatic cylinder out of 3/4" pvc. this is literally the 1st step in seeing if my idea can move forward. i made the piston in CAD and had my machine guy carve it up for me in 6061 AL. its a dual o-ring design, the upper is more of a wipe than it is a seal, but this 1st test proved promising. i need about ~25lbs of lift to get TV up (TV weighs just 22lbs). my 1st test was to see if i could generate some force using compressed air, and yikes, this thing can certainly create some force. i wedged it between my shipping scale on table and a fixed shelf, and with not much air at all the thing was into 60lb area w/o blowing the seal(s). i need to now take it into phase-2 of testing to see 1) how much psi do i need to lift ~25lbs (ez to calc, but there's some drag due to o-rings, etc), and 2) once pressurized i need to see if i can hold it at that psi w/o leak-down, and 3) can pneumatic work 100% in a operating temp of 25-110F. not that ez, but a challenge i am up to.
